lowering bike
lowering bike
alright i need to lower my bike at least 2 inches i see on e-bay there is a lowering kit which is two bars with 3 holes to adjust high 1 is stock one is 1.5" drop and oe 3" drop.....if i buy this will there be anything else i need to lower the rear down some? or does anyone know a good kit out there..i have a 1989 fzr 600. thank you.
1989 fzr 600 candy silver base coat, black frame ,voltage up-grade amoung much more
- kilika2
- 1000+ Posts
Re: lowering bike
Reelrazor has an even better kit than that. I know nothing about the one on ebay, and I haven't used his (yet) but I know his is way better.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
Re: lowering bike
What about lowering the front? How is that done?
Re: lowering bike
Drop the forks through the triples...shigs wrote:What about lowering the front? How is that done?
...OR let air pressure out of the front tire. j/k
Re: lowering bike
just lean farther over! haha
careful when you are lowering through the triples, as once you turn the bolts enough it will slide pretty quick, just make sure you keep enough tension on the clamp to have it slide slow.
The lowering links on ebay are fine, you will just replace your stock ones with the ebay ones. 2 bolts underneath, you will see. you might want to have a friend there to hold up the rear of the bike as once you pull the bolts the backend is going to drop. otherwise it is an easy installation.
Reelrazors are very nice also, and they let you adjust the height. not sure the exact measurements, but i'm sure he has them.
I did that.
Re: lowering bike
I had them and didn't really like them. I'm buying the reelrazor ones now. The ebay ones are ok. On mine, one side of the bolt (where the dogbones attached to) didn't fit. I ended up cutting off one of holes to make it fit properly. I would suggest save your money from the ebays one and buy the adjustable ones from reelrazor.jos21802001 wrote:alright i need to lower my bike at least 2 inches i see on e-bay there is a lowering kit which is two bars with 3 holes to adjust high 1 is stock one is 1.5" drop and oe 3" drop.....if i buy this will there be anything else i need to lower the rear down some? or does anyone know a good kit out there..i have a 1989 fzr 600. thank you.
Danny.
Re: lowering bike
the Ebay 3 hole ones leave a lot to be desired ie not enough "meat" between holes for safety .
I have ReelRazor dog bones on mine and they passed our state inspection ( MOT ) where as the 3 holes did not !
If you lower the back 2" then the front should be lowered equally or the bike's handling is SEVERELY compromised around town in particular.
Re: lowering bike
yamaha_george wrote:Hi,
Whats the best way to go about lowering the front??
Re: lowering bike
shigs wrote:Whats the best way to go about lowering the front??
ragedigital wrote:Drop the forks through the triples...
Target30 wrote:careful when you are lowering through the triples, as once you turn the bolts enough it will slide pretty quick, just make sure you keep enough tension on the clamp to have it slide slow.
Re: lowering bike
So theres no modding the forks or fitting shorter forks to lower the front? Sliding them through the triples is the ONLY way?
Re: lowering bike
I'm certain for a couple thousand you can send them to RaceTech and they'll shorten them for ya.shigs wrote:So theres no modding the forks or fitting shorter forks to lower the front? Sliding them through the triples is the ONLY way?
How much are you looking to shorten them?
Re: lowering bike
guys was there not some discussion on using R6 or R1 forks which for the standard set up bike too short for the FZR?
I know ducati are way too short (I had a spare set of Duc USD fully adjustable forks & trees and I had to lose that idea )
Re: lowering bike
http://www.frankmain.qpg.com/
'Forking by Frank'
Been around forever, will custon make tubes in over or under length
'Forking by Frank'
- sleepyz0mby
Re: lowering bike
every time i tried to lower my fzr the rear tire bottoms out... i'm only 130-ish 140 on a wet day... maybe my shock needs to be rebuilt? but thats my experience with lowering.
Re: lowering bike
It's a very soft suspension to begin with. Using an updated R6 shock would probably help. I do believe that ReelRazor still sells the R6 shock kit.sleepyz0mby wrote:every time i tried to lower my fzr the rear tire bottoms out... i'm only 130-ish 140 on a wet day... maybe my shock needs to be rebuilt? but thats my experience with lowering.
