We all know the dangers of a snapped chain, if you don't there's a thread here somewhere that is quite scary! Thats not the only issue, a dry chain consumes energy = less MPG E.T.C. Wears the chain and sprockets prematurely.
I've recently fitted a Scottoiler RMV (Reservoir Metering Valve) works off engine vacuum and oils the chain as you ride, a Dual Injector oils both sides of the chain, and a Lube Tube which holds an extra 200ml of oil.
Scottoiler's are manufactured in Scotland, read up here http://www.scottoiler.com/
Now I just need to finish everything else up and get some riding done. Damn FLU
