- Brutal Tooth
Re: 89' 14t/50t conversion? Who has done this?
I ran a 14/49 combination. What are you looking to accomplish?
- Brutal Tooth
- Brutal Tooth
Depending on your weight, that should get the wheel off the ground. If you want more control, like the majority of stunters, then you want a larger rear sprocket - maybe a 54t or larger and a 13t front sprocket. Course, your mileage will suck and your top speed will suffer, but you'll take off like a "bat outta hell!"
I ran the 14/49 to pull out of the corners harder at Track Days.
- Brutal Tooth
Don't forget to yell, "Yut-Ughhh!!"
I'm sure that combo would work fine, but high RPMs are necessary to get it off the ground.Brutal Tooth wrote:But I am pretty sure that a 14/50 would pop wheelies w/o high RPMs, wouldn't it?
