Shreds 94' YZF600R (She lives! Need some running help)
In the states, this was the upgrade to the FZR600. In other places, this is called an FZR. Either way, many of the components of the US YZF600r fit onto the US FZR600.
shredex
Re: Shreds 94' YZF600R (She lives! Need some running help)
Post by shredex »
white smoke is no more, I didnt upload the video where its not smoking.
I know how to sync the carbs...lol...
two bottle method!
reelrazor
Wrench
Wrench
Post by reelrazor »
shredex wrote:put new plugs into 3&4 but still reading only about 115 degrees...i dont have a multimeter to test the coils but I might stick my fzr coils on it and try again
It won't be coils because #3 and #4 are on separate coils. If you have a coil issue it will run on #1 and #4, or on #2 and #3.
shredex
Post by shredex »
yea, I knew that but just figured maybe the coil wires were swaped around lol.
I started the wire that said "1" on the clutch side and ended with "4" on the brake side.
Ill tear into carbs tomorrow morning and try cleaning them more.
shredex
Post by shredex »
ok, did thorough cleaning on the carbs. pulled off every jet and cleaned avery passageway and nuck and cranny.
threw them on the bike
she ran, revs went up after about 1 min and disengaged choke and she still ran.
then I synced the carbs.
Im able to give her throttle and it revs up and everything good...doesnt sound right though...might need to drill out caps and adjust A/F screws
but there is one problem, if I really quickly snap open the throttle then the rpms go to low and almost stalls out. but if I do it at a nice pace then she will rev up.
its just if I snap it from idle.
I put it in 1st and the rear spun so that good...looks like clutch needs adjusting though...lol
vid in a little bit
touch
Post by touch »
I am having the same problem with the off-idle stumble. My next steps will be to check the float height and synch the carbs; it the problem remains then off they come again for Carb Cleaning Part II. Definitely following this thread to see if there is some quick and easy answer (or at least an answer).
Post by sweekster »
shredex wrote: Im able to give her throttle and it revs up and everything good...doesnt sound right though...might need to drill out caps and adjust A/F screws
Sounds rich still bub. What do you have it idling at?
shredex
Post by shredex »
Post by sweekster »
Ok we need video of you riding it. With the fuel bowls full you should have at least a minute or two of ride time. Up the street and back. Do it..
shredex
Post by shredex »
sweekster wrote:Ok we need video of you riding it. With the fuel bowls full you should have at least a minute or two of ride time. Up the street and back. Do it..
back tire needs air lol.
and I gotta adjust the clutch right because it doesnt engage as of now.
kenand1988
Post by kenand1988 »
A friend of mine encountered this very problem with his xj600. Clean your jets or completely replace them. Make sure the idle screw is set right. Check your coil packsm make sure theyre all getting the right amount of power. How old is the battery in it? You are going to have to let that thing sit and run with it on full or half-choke for a good long while. Change any other fluids you can. The white smoke is the starter fluid, seafoam, stuff you used to clean the carbs with and/or old gas in the lines. Which brings me to another suggestions, inspect your gas lines and fuel filter.
match417
Level 8.0
Level 8.0
Post by match417 »
shredex wrote:if I really quickly snap open the throttle then the rpms go to low and almost stalls out. but if I do it at a nice pace then she will rev up.
are you still running it without the airbox on like in the videos? It will do that without the airbox on or with an incorrect a/f ratio.
shredex
Post by shredex »
dirty is an understatement
fightered out wheelie machine! and the ultra fightered out paper weight
no clue what the fluck that was
shock bolt suppose to be tappered like that?
ecky
after cleaning...lol
the motor I pretty much just took a wire wheel to and got what I could...need to find some good cleaning solution
how the fluck do you remove that sprocket anyways? its a 530 14T
like barney
WTH is that slit? the top part measure 3/8" out but its crooked! could have used it as my cutting line
match417
Level 8.0
Level 8.0
Post by match417 »
shock bolt: I've seen bolts similar to that, it looks like it's supposed to be tapered.
sprocket removal: I used an impact gun.
R3TARD
Level 4.5
Level 4.5
Post by R3TARD »
match417 wrote:shock bolt: I've seen bolts similar to that, it looks like it's supposed to be tapered.
Make sure bike is in Neutral first bub
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
shredex
Post by shredex »
lol. not like the motor without carbs can run for awhile
I think im gonna leave that sprocket on unless 520 is nessesary for clearance
