o ok, so just put it in first, then when going to 2nd, keep on the throttle and shift w/o the clutch, and if it DOES shift, the clutch is the problem. If it doesn't, it's the trans. RIGHT?haro504 wrote:power shifting is how i described it you just shift it without the clutch. when you pull up on the shifter while accelerating it wont shift till you come off the throttle when the pressure is off the trans it shifts quite smothly i might ad then you hammer on and go through the next gear eliminating the possibility of the clutch draging so if it works its your clutch if it doesent its your trans. its just like using the clutch to shift but you dont. you would need it to start off though.
Thanks,D
