will fzr400 coils work on the fzr600?
shredex
Post by shredex »
what about yzf600 coils?
95FZR600
Re: will fzr400 coils work on the fzr600?
Post by 95FZR600 »
Ask Cad or Billy.
Post by sweekster »
From the quick look I just took at both wiring diagrams for the YZF and the FZR it looks as if the YZFs can at least be wired in. Whether they will actually fit is a different story...
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
I think they both work. I don't believe the 400s had the same output if IIRC.
I may have a set of YZFs... I'll check later this evening.
shredex
Post by shredex »
i asked about the 400 coils because finch has a set he can hook me up with and id like to see if they would even work before he sent them over
Post by sweekster »
shredex wrote:i asked about the 400 coils because finch has a set he can hook me up with and id like to see if they would even work before he sent them over
They probably would work but they aren't plug and play (you'd still have to wire them in) and I would suspect the spark signal would be weaker than the 600 ones. The YZF's may have a stronger signal than the fzr and could probably give a performance boost.
the_finch
Level 8.5
Level 8.5
Post by the_finch »
I don't know alot about ignitions, but doesn't it take about the same amount of power to throw a spark over a gap no matter what? So in theory if the FZR400 and FZR600 had the sam stock gap in their plugs, the 400 coils would be powerful enough to throw a spark for the 600?
Also, anyone know what the primary and secondary resistances are for the stock FZR400 coils? If I send these to Shred, I want to make sure they're useable first.
1997 FZR600RJ
DonTZ125
Moderator
Post by DonTZ125 »
Primary: 1.8-2.2 Ohms @ 20C / 68F
Secondary: 9.6-14.4 k Ohms @ 20C / 68F
shredex
Post by shredex »
DonTZ125 wrote:Primary: 1.8-2.2 Ohms @ 20C / 68F
thats for the fzr600...is the fzr400 the same?
DonTZ125
Moderator
Post by DonTZ125 »
Since I copied them from the 400 manual, I'm going to assume so... :banana:
shredex
Post by shredex »
that means there the same :D
we should find the specs on the yzf coils to find out if it produces a bigger spark...then we wont have to search down ford coils and have to have pods do to space problems...just for future reference
the_finch
Level 8.5
Level 8.5
Post by the_finch »
Thanks Don. Headed out to check the spare 400 coils in the shop....after I get done playing with suspension bearings. banghead
1997 FZR600RJ
reelrazor
Wrench
Wrench
Post by reelrazor »
The 400 coils are functionally the same, mount the same too if I am not mistaken. I'd put 'em on.
the_finch
Level 8.5
Level 8.5
Post by the_finch »
I checked and they're within spec. As far as mounting, the 400 coils I have are individually mounted, one on each side of the "engine bay". However, they have the bolt go through the top like the 600 so you should be able to pull them off of the stock mounts and bolt them to a FZR600 mount and mount them right in.
1997 FZR600RJ
