can you fit later model yammie hand levers, you know the ones that give you 4/5 parts of adjustable span ????
thanks
dave
adjustable (hand) levers
Re: adjustable (hand) levers
Yes you can,
I have an adjustable R6 break lever and Master Cylinder. It is possible, not sure about the Clutch lever. Here's a picture of my setup.
Looking for a FZR 400 3TJ
1992 FZR 600 SOLD
2001 Ducati ST4 916
Chipped, with Fast By Ferracci cans
The Yellow Duc Project
The lord tells me he can get me outta this mess but he tells me he's pretty sure your f***ed.
1992 FZR 600 SOLD
2001 Ducati ST4 916
you can adjust your lever reach on the clutch by way of the adjustment screw and backout bolt where the clutch cable starts. here is a pic reference:
obviously those levers have a reach adjustment built in. even if you do not have fancy levers, you can still adjust your lever so that the lever sits closer to the bar. simply unscrew the back off nut away from the lever (the big, thin "disc" part), and then screw the adjuster into the clutch a little bit. check the play of the clutch lever as you do so to find the feel you like. if you decide to set it back to original, make sure to leave a little free play in the lever. if you over tighten it, you will be engaging the clutch and eating up your clutch plates, losing power, etc.
it's an easy adjustment to do. or just buy levers with a switch on them. heh heh
..........................................................shitf.............................c3po...................next.victim............................................................
to see some of my ride videos, click the link: http://video.google.com/videosearch?q=b ... oogle.com#
may 2009: my 88 fzr 400 sets a speed record at the maxton mile: http://www.youtube.com/watch?v=GlOk-6aUsKc
Oh to have some Pazzo levers or CRG. Damn them for being 90 a pop!
Do YOU Scopper?
You can use the 99-02 r6 levers and perch on an FZR.
d,corks67 wrote:can you fit later model yammie hand levers, you know the ones that give you 4/5 parts of adjustable span ????
thanks
dave
Yes see:-
http://www.saltmine.org.uk/fzr/frontbrakes.html
3rd or 4th picture down. Nerd
Replace with 99-02 R6 perch and levers and just add the adjustable ones. They make them for that model both clutch and brake. The clutch ones are high dollar and come in different colors.
