still running rich
shredex
still running rich
Post by shredex »
My bike is running awesome and has great performance...and yet...
my nice clean exhaust I just put on is now coated with a nice layer of black crap.
I have my mixture screws set at 1 1/2 turns out. people usually have theres at 2 or 2 1/2.
my needle clip is set on the first setting from the top.
should I move it to the second notch and start from there?
I just dont see how im still running rich
csofos
Level 4.5
Level 4.5
Re: still running rich
Post by csofos »
Have you got any jet change? If the jets are bigger, then the rich running it's logical. If you rise the needles (ie 2nd position or more) you'll ger richer running. What do you mean whaen you say rich??? What is your midlle fuel consumption?
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
Replacing the emulsion tubes made a huge difference on my fizz. Mine would run rich no matter what setting I used.
deathcomesarippin
Post by deathcomesarippin »
has it been doing this since you put that header and the new can on? bring it over to my place sometime and we can mess with it
modded air box,
K&N drop in,
race tech fork springs,
R6 header-kerker exhuast,
things to come, 520 conversion, jet kit, yzf front brake calibers
shredex
Post by shredex »
its been running rich since I got it.
I checked my emulsion tubes just about 2 months ago and no wear.
Post by sweekster »
You may need to resynch. I'd start there
haunter
Post by haunter »
its pretty hard to eyeball emulsion tube wear
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
haunter wrote:its pretty hard to eyeball emulsion tube wear
+1, I Looked at mine a dozen times and they looked fine. Darrin finally convinced me to replace them. They seem to wear out after about 12k miles.
deathcomesarippin
im just a noob Noob ,but I dunno could be wrong (most of the time haha) but I though if the emulsion tubes where bad it could lean it out instead of it going rich?
and this thing is awesome! squid
modded air box,
K&N drop in,
shredex
Post by shredex »
I actually did more than just eyeball
I used a magnifying glass and also took up close pics of them and blew them up on my computer to check for wear.
i think maybe I could use individual pod filters or dual filter and this would bring better air flow and my richness will subside.
I only have a k&n drop in filter.
tommyj27
Level 9.5
Level 9.5
Post by tommyj27 »
deathcomesarippin wrote:im just a noob Noob ,but I dunno could be wrong (most of the time haha) but I though if the emulsion tubes where bad it could lean it out instead of it going rich?
(Someone correct me if I'm wrong) As the tubes wear they enlarge internally, allowing more fuel to flow around the needle and creating the rich condition that we know and love.
Post by sweekster »
tommyj27 wrote: (Someone correct me if I'm wrong) As the tubes wear they enlarge internally, allowing more fuel to flow around the needle and creating the rich condition that we know and love.
Cannot correct what is already correct.
fzrbrandon
Level 7.5
Level 7.5
Post by fzrbrandon »
Hey Shredex,
You may want to double-check your float height.
*EDIT* Oh, and don't switch to pods just to try and rectify a richness problems. You'd be opening up another can of worms there.
Brandon
Image Image
http://www.fzrbrandon.com
deathcomesarippin
ok cool thanks for clearing it up for me!
modded air box,
K&N drop in,
reelrazor
Wrench
Wrench
Post by reelrazor »
"first setting from the top"
"1 &1/2 turns out"
And: "rich"
= does not compute
at least without what someone else here suggested...check float heights and most likely lower them a little
