abs600fzrr wrote:use this chain...http://cgi.ebay.com/ebaymotors/RK-XSO-R ... ccessories
Actually I that exact same chain except 120 link for 54 shipped. I got lucky.
I am cutting the arm today. I will take some pics.
95FZR600 wrote:Dont forget to have your buddy weld on some spool brackets.
jax wrote:95FZR600 wrote:Dont forget to have your buddy weld on some spool brackets.
Im not going to worry about that now because this thing is already running me close to 500 bucks. I honestly never had any use for a swingarm stand since I use a jack if I need to lube my chain or whatever. Although if I did decide to weld them on then I would have to go buy a 100 dollar stand to go with it as well.
I think the 8.46 distance will be OK. Tonight I will cut the caps and measure again. If Im close to 8.75 with the caps on by a few hundreds then I should be good to go. I can use a thin shim if I have to.
gold plated i presume?95FZR600 wrote:You paid $200 for the swinger?
megaloxana wrote:gold plated i presume?95FZR600 wrote:You paid $200 for the swinger?
95FZR600 wrote:Looking good.Keep us updated with pics and paint it whatever color your frame is.
jax wrote:Here is a picture of the swingarm after I cut it. It sits right between 8 & 7/16ths - 8 & 1/2. The camera angle makes it seems a little less but its not.
