Help from those with fairings
thatkid
Post by thatkid »
If those of you who had stock fairing and airtec kits could take a few measurements for me it would be greatly appreciated. I'm trying to get the final lengths for the race rails and I want to make sure they will fit around fairings but I don't have any.
So the measurements I need are from the front engine mount on the downtubes straight out on each side. I need to know the length from the downtube mount to the outside of the fairings. I need this for both sides.
I also need the measurement from the top motor mount to the outside of the fairings.
This is what the rails look like. I need measurements at the beginning, end and middle of possible. I want it to hug the fairing as tight as possible but not rub so accurate measurements would be very helpful. I'm hoping the airtech are close enough to the stock measurements that I'll only have to make one size.
Thanks for whomever can help me out.
Do YOU Scopper?
thatkid
Re: Help from those with fairings
Post by thatkid »
Anyone???
Do YOU Scopper?
WNY ROGO
Level 2.5
Level 2.5
Post by WNY ROGO »
I wish I could help you but I dont have a bike yet lol. Sry dude, but when you do get the mockup I will want some, powdercoated too lol.
...ROGO...
1993 Yamaha Fzr 600-RIP
Stock
1990 Yamaha Fzr 600-Current
Mods
Updated R6 Voltage Regulator/Rectifier
Flush mount Front Signals
R6 Headers Modded By That-Kid
Leo Vince R6 Highmount Exhaust
520 Chain and Sprocket Conversion
YZF600R Front End Swap
Front and Rear YZF600R Brake Swap
YZF600R Swingarm Swap
92 Fzr Single Upper
8000k HID Headlight Kit
95 YZF600R Gauge Cluster
02 R6 Tail, Fender Eliminator and Intergrated Tailight
YZF600R Gas Tank
Rear Tire Hugger
http://www.myspace.com/rogo420
facebook---Andrew Rogo Rogowski
Fzr Forum===WnyRogo93Fzr
thatkid wrote:If those of you who had stock fairing and airtec kits could take a few measurements for me it would be greatly appreciated. I'm trying to get the final lengths for the race rails and I want to make sure they will fit around fairings but I don't have any.
This is what the rails look like. I need measurements at the beginning, end and middle of possible. I want it to hug the fairing as tight as possible but not rub so accurate measurements would be very helpful. I'm hoping the airtech are close enough to the stock measurements that I'll only have to make one size. Thanks for whomever can help me out.
TK,
May I suggest you do a photoshop marked picture of what you want where etc . Words in this situation are just not clear enough (that or my wife used too much cooking sherry again LoL)
95FZR600
Post by 95FZR600 »
Are you wanting the width? Like from frame out to where your tube is?
thatkid
Post by thatkid »
I need the distance from frame out to where the fairing is. Basically, if my picture above had fairings, how far out would my bar need to be in order to not rub the fairing. I need to know the two mounting points and a middle point for good measure.
Do YOU Scopper?
shredex
Post by shredex »
TK, youll need about a 4" clearance space between the bar and the frame where you have it mounted in the pic.
you can use the peanut cover as spacing because the end of that sits flush with the fairings.
95FZR600
Post by 95FZR600 »
What you really need is a fairing to put on to test fit it. All that shit you had for sale and no fairings? IDK
thatkid
Post by thatkid »
95FZR600 wrote:What you really need is a fairing to put on to test fit it. All that shit you had for sale and no fairings? IDK
Oh I have a set of beasley fairings. I don't have a way to mount them though and I don't want to drill them in case I decide to sell them and the next person doesn't want race rails.
That's why I need you to be the greatest person ever and get me some measurement. :king
Do YOU Scopper?
megaloxana
Post by megaloxana »
thatkid wrote:That's why I need you to be the greatest person ever and get me some measurement.
yeah you southern boys with your warm weather get your asses outside and measure bonkonhead
'92 FZR 600
mossy1200
Level 5.0
Level 5.0
Post by mossy1200 »
Spreed you legs if your going to hit something solid.Wouldnt want to break legs....
95FZR600
Post by 95FZR600 »
Its 36 degrees right now
thatkid
Post by thatkid »
Well it's 17 here. There has to be more than like 2 people on this forum that have full fairings. Come on people....where is the love for helping out a fellow board member??
Do YOU Scopper?
thatkid
Post by thatkid »
mossy1200 wrote:Spreed you legs if your going to hit something solid.Wouldnt want to break legs....
huh?
Do YOU Scopper?
olie05
Level 2.0
Level 2.0
Post by olie05 »
From the right side frame to the fairing: a little under 2.5"
From the right side crank case (where a bolt threads into from the bottom) to the fairing: 2 - 1/8"
left frame to fairing: 2.5"
left timing nub to fairing: a little under 2"
My bike has been down on the right side FYI. Also, you should get more measurements from other people to verify.
I also want to mention that these things are going to stick out really far if you are going to make them fit around the fairings. The fairings stick out quite a bit already. I would not put them on my bike, because they would kill the lines and make the bike look horrendous.
I guess I was the one with the warmest climate. It's about 50 degrees right now in Houston.
ok no more editing :P
