So the measurements I need are from the front engine mount on the downtubes straight out on each side. I need to know the length from the downtube mount to the outside of the fairings. I need this for both sides.
I also need the measurement from the top motor mount to the outside of the fairings.
This is what the rails look like. I need measurements at the beginning, end and middle of possible. I want it to hug the fairing as tight as possible but not rub so accurate measurements would be very helpful. I'm hoping the airtech are close enough to the stock measurements that I'll only have to make one size.
Thanks for whomever can help me out.
