01 R6 factory exhaust on a 94 fzr
I have a 94 fzr 600 and found a 01 R6 factory exhaust for cheap. The exhaust includes the header and pipe. Would this stuff fit onto my bike and would I notice any type of gains. As far as I know the FZR isnt jetted. Thank you
Re: 01 R6 factory exhaust on a 94 fzr
With a little fab work it will work, but I dont think it will add any significant power. Maybe if you do surgery and repack it and cut it down a bit. Just the can that is. With Full modded exhaust yes, as described below.
...ROGO...
1993 Yamaha Fzr 600-RIP
Stock
1990 Yamaha Fzr 600-Current
Mods
Updated R6 Voltage Regulator/Rectifier
Flush mount Front Signals
R6 Headers Modded By That-Kid
Leo Vince R6 Highmount Exhaust
520 Chain and Sprocket Conversion
YZF600R Front End Swap
Front and Rear YZF600R Brake Swap
YZF600R Swingarm Swap
92 Fzr Single Upper
8000k HID Headlight Kit
95 YZF600R Gauge Cluster
02 R6 Tail, Fender Eliminator and Intergrated Tailight
YZF600R Gas Tank
Rear Tire Hugger
http://www.myspace.com/rogo420
facebook---Andrew Rogo Rogowski
Fzr Forum===WnyRogo93Fzr
Stock
Mods
92 Fzr Single Upper
YZF600R Gas Tank
Rear Tire Hugger
Oh the header will add some HP. It's larger than the stock FZR header and it's a 4-2-1 system. I sell modified R6 headers that will bolt right up to the FZR motor. The can won't really do much except add a different tone.
Do YOU Scopper?
So how much work would need to be done to get the header to fit and would the carbs need to be jetted.
jams wrote:So how much work would need to be done to get the header to fit and would the carbs need to be jetted.
The carbs will not need to be re-jetted.
- the_finch
- Level 8.5
If I remember right, any mods to a carb'd sytem, have to tune the carbs to the new settings, even if you don't re-jet them. Meaning you could probably adjust your fuel mixture screws a little for the decreased backpressure, though I don't entirely know, as I haven't messed with tuning my carbs too much yet.95FZR600 wrote:jams wrote:So how much work would need to be done to get the header to fit and would the carbs need to be jetted.
1997 FZR600RJ
The carbs WILL have to be rejetted or jetted if they aren't. The R6 header mod is basically adding an aftermarket full exhaust system to the fizz. That kind of breathing increase will require some carb work.
Do YOU Scopper?
The tubes need to be spread to fit the fzr head. There is cutting/grinding and welding involved. Not hard if you have a spare head to mock it up on. Then you have to weld spacers inbetween the tubes to keep them spread.jams wrote:So how much work would need to be done to get the header to fit and would the carbs need to be jetted.
Do YOU Scopper?
