How to stop exhaust from rusting
lloydspencer
Post by lloydspencer »
I And looking at getting a full vance and hines race system for my fzr600. The only problem is i have heard they rust very easily. Living in the uk and be an all weather rider means i will be riding in some harsh conditions. Any ideas to prevent rusting my lovely new exhaust system?
Loud Pipes Save Lives.
reelrazor
Wrench
Wrench
Re: How to stop exhaust from rusting
Post by reelrazor »
How to prevent exhaust rust?
Store the bike in a climate controlled low humidity environment. Never EVER ride it....hell, never EVER start it....
ahahhahaha I crack myself up!
Good high temp paint. Heat cure it. Couple coats....
I am thinking about sandblasting mine then doing some kind of controlled oxidation process. My boss does that with some of his metal sculptures
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
lloydspencer wrote:I And looking at getting a full vance and hines race system for my fzr600. The only problem is i have heard they rust very easily. Living in the uk and be an all weather rider means i will be riding in some harsh conditions. Any ideas to prevent rusting my lovely new exhaust system?
There are 2 different systems but the Headers are generally know to have the rusting problem. You need to get them powdercoated with a high temp powdercoat. Or chromed or something.
Upgrades:
thatkid
Post by thatkid »
You can also have them ceramic coated. While pricey, you shouldn't have to worry about them ever again.
Do YOU Scopper?
abs929cbrrr
Post by abs929cbrrr »
DUCT TAPE
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
95FZR600
Post by 95FZR600 »
Header wrap?
abs929cbrrr
I rear they rust inside out but what do i know im abs
haunter
Post by haunter »
95FZR600 wrote:Header wrap?
supposedly it accelerates it cuz its gets wet and is sitting on teh header pipes
reelrazor here saying:
yeah, that's the evidence I have seen with my own eyes. Especially if every single ride isn't enough to dry the wrap right out. But headers that have been in it for any length of time tend to just be flat rotten. Better to remove and sandblast every couple years and header kote them- in my opinion.
Don't know why it posted me as haunter..
being near the sea aint gonna help too much with corrosion of any sort.
Ceramic coating does work (why the Military use it on Jeeps and such.
Header wrap will kill pipes in about 50% of the time unwrapped pipes will die.
They do rust from the inside out as well
should last about 10 years with care
Here endeth the lesson :-}
95FZR600
Post by 95FZR600 »
spray it with WD-40 every day?
reelrazor
Wrench
Wrench
Post by reelrazor »
Seriously, I am thinking gunbluing, or some other controlled oxidation process the next time around. I'm gonna hit my boss up for info on that kind of stuff
reelrazor wrote:Seriously, I am thinking gunbluing, or some other controlled oxidation process the next time around. I'm gonna hit my boss up for info on that kind of stuff
RR,
try a stuff called KLotz GunKote. just take the pipes off take a propane torch and run the flame thro each pipe & spray with GunKote then run the torch thro again to bake it on. I have aset of 29 year old custom expansion chambers done like that on one of the RD's back home .
Loved the smell of the red Klotz 2 stroke oil <BG>
95FZR600
Post by 95FZR600 »
for real, couldnt you blue them? You can buy a small kit at the gun store and do it yourself. Shit, i have parkerized a couple ak's but that is a darker finish.
95FZR600 wrote:for real, couldnt you blue them? You can buy a small kit at the gun store and do it yourself. Shit, i have parkerized a couple ak's but that is a darker finish.
RR,
Yup you could but it is not as effective from experience in the windies at least it may be better in the colder climate.
reelrazor
Wrench
Wrench
Post by reelrazor »
This is the company I work for..the art page of the owner's check out "assorted flowers"..none of that is paint he heats and coats the metal then washes it off leaving a finish..colored or not...the green is a copper sulfate I think...the brown on the 'trunk' of the sunflower, I dunno...and the the yellows??
http://www.moraniron.com/moraniron-artwork.html
Most of his stuff sits outside...some of it for years and it seems pretty impervious.
