I am fixing all the small problems with the FZR I just bought and I think the idle maybe a tad on the high side. Mine idles around 1k-1.5k when warm. What does your guys bikes idle at when fully warmed up and off the choke?
Thanks for the info,
Dan
Idle Question
dans96fzr600
Idle Question
1996 Fzr 600
D&D Pipe
K&N Filter
Jetted Carbs
520 Sproket Conversion
Yes it moves well for a 600cc
D&D Pipe
K&N Filter
Jetted Carbs
Re: Idle Question
I'd say you're in the hunt. Idle accoring to Clymer's is 1,150 - 1,250 unless you have a Cali then add 100 revs to each end.
dans96fzr600
Re: Idle Question
Thanks for that info! I think mine might just sound a little high because the D&D pipe I have is so loud that it makes me think it has to be too high at idleM in KC wrote:I'd say you're in the hunt. Idle accoring to Clymer's is 1,150 - 1,250 unless you have a Cali then add 100 revs to each end.
1996 Fzr 600
D&D Pipe
K&N Filter
Jetted Carbs
D&D Pipe
K&N Filter
Jetted Carbs
Re: Idle Question
Dan,dans96fzr600 wrote:I am fixing all the small problems with the FZR I just bought and I think the idle maybe a tad on the high side. Mine idles around 1k-1.5k when warm. What does your guys bikes idle at when fully warmed up and off the choke?
Dan
Thats fine, you will find that the FZR hates below 1K and will not pull cleanly, you are correct that with a loudish pipe it sounds as though it's a couple of C's over revving.
Better to listen for a steady beat rather than the noise as such, and that when pulling off and returning to idle it is clean no stumbling.
dans96fzr600
Re: Idle Question
Dan,
Better to listen for a steady beat rather than the noise as such, and that when pulling off and returning to idle it is clean no stumbling.[/quote]
Thanks for the info I really think its the pipe playing tricks on me like I said. Because its just as you described it pulls super super clean. And when it returns to idle its always rock solid and doesnt surge or any thing.
Dan
Dan
1996 Fzr 600
D&D Pipe
K&N Filter
Jetted Carbs
D&D Pipe
K&N Filter
Jetted Carbs
