Throttle cable just snapped
Re: Throttle cable just snapped
shredex wrote:anyone know if I can use my return cable as my throttle???
NO.
Get new ones.
Fight a different battle on a different day.
- shredex
- 2000+ Posts
I did work.
I just switched them...
Im not going to keep it that way...
anyone know where I can get a new one? are they cheap?
Check BikeBandit or Dennis Kirk, I don't think they are very expensive, maybe $20.00 if that
92 FZR600
Dual Headlight Upper Swap
Clear Taillight w/LED Bulbs
More To Come
More To Come
- billy_awesome
- Level 2.0
You will probably have to wait for it too, seems like FZR parts are always on backorder.....
damn these old bikes.....
I just got a throttle and return cable from bikebandit for very cheap. I went with the motion pro ones.
Upgrades:
- shredex
- 2000+ Posts
which one is the throttle cable??
Motion Pro Throttle Pull Cable ??
Motion Pro Throttle Push Cable?
Im going to assume its the first because its more expensive
Just replace them both. You're digging around your bike anyways, you might as well replace both and avoid the hassle of doing it all again when the other snaps.
and, well, pull is the one that pulls the carbs open, push is the one that pushes them closedshredex wrote:which one is the throttle cable??
Upgrades:
- shredex
- 2000+ Posts
if you think about it, they BOTH pull...The return cable PULLS the carbs closed.zero9243 wrote:
Think of your throttle hand. You pull the throttle open and push it closed.shredex wrote:if you think about it, they BOTH pull...The return cable PULLS the carbs closed.zero9243 wrote:
Upgrades:
