Moderators: Site Director , FZR Forum Moderators
shredex
Posts: 2768 Joined: Sun Sep 07, 2008 10:40 am
Post
by shredex » Thu Nov 27, 2008 2:22 pm
shredex
Post
by shredex » Thu Nov 27, 2008 2:25 pm
anyone know if I can use my return cable as my throttle???
reelrazor
Wrench
Posts: 1658 Joined: Sun Oct 05, 2008 8:19 am
Post
by reelrazor » Thu Nov 27, 2008 3:02 pm
shredex wrote: anyone know if I can use my return cable as my throttle???
NO.
Get new ones.
Fight a different battle on a different day.
shredex
Post
by shredex » Thu Nov 27, 2008 3:36 pm
I did work.
I just switched them...
Im not going to keep it that way...
anyone know where I can get a new one? are they cheap?
tkclow
Level 5.5
Posts: 556 Joined: Sun Sep 14, 2008 6:30 pm
Post
by tkclow » Thu Nov 27, 2008 3:45 pm
Check BikeBandit or Dennis Kirk, I don't think they are very expensive, maybe $20.00 if that
92 FZR600
Dual Headlight Upper Swap
Clear Taillight w/LED Bulbs
More To Come
billy_awesome
Level 2.0
Posts: 215 Joined: Fri May 09, 2008 9:49 am
Post
by billy_awesome » Thu Nov 27, 2008 4:27 pm
You will probably have to wait for it too, seems like FZR parts are always on backorder.....
damn these old bikes.....
zero9243
Level 8.5
Posts: 896 Joined: Wed May 28, 2008 3:23 pm
Post
by zero9243 » Thu Nov 27, 2008 5:34 pm
I just got a throttle and return cable from bikebandit for very cheap. I went with the motion pro ones.
Upgrades:
Barnett Clutch------------------------------------------R6 Blue Dots, Front Master Brake Cylinder+Reservoir
shredex
Post
by shredex » Thu Nov 27, 2008 5:39 pm
which one is the throttle cable??
Motion Pro Throttle Pull Cable ??
Motion Pro Throttle Push Cable?
Im going to assume its the first because its more expensive
tommyj27
Level 9.5
Posts: 970 Joined: Wed May 07, 2008 10:59 am
Post
by tommyj27 » Thu Nov 27, 2008 11:47 pm
Just replace them both. You're digging around your bike anyways, you might as well replace both and avoid the hassle of doing it all again when the other snaps.
zero9243
Level 8.5
Post
by zero9243 » Fri Nov 28, 2008 10:41 am
shredex wrote: which one is the throttle cable??
and, well, pull is the one that pulls the carbs open, push is the one that pushes them closed
Upgrades:
shredex
Post
by shredex » Fri Nov 28, 2008 10:49 am
if you think about it, they BOTH pull...The return cable PULLS the carbs closed.
zero9243
Level 8.5
Post
by zero9243 » Fri Nov 28, 2008 11:45 am
Think of your throttle hand. You pull the throttle open and push it closed.
Upgrades:
