spark plug keeps going out
shredex
Post by shredex »
this is the second time in less than a month that Iv have to replace the spark plug in my first head. banghead
what could cause a premature spark plug death?
mike94fzr600
Level 4.5
Level 4.5
Re: spark plug keeps going out
Post by mike94fzr600 »
what does the end of the plug look like
my rides
2000 chevy z71 4x4
1993 Suzuki Samurai my mud \ trail toy
1994 fzr 600
shredex
Post by shredex »
mike94fzr600 wrote:what does the end of the plug look like
black. and it smells like fuel.
mike94fzr600
Level 4.5
Level 4.5
so maby its rinnin rich. if iot gets to wet with gas it would make the plug go bad
my rides
2000 chevy z71 4x4
1994 fzr 600
shredex
Post by shredex »
well, I know im running rich because I just cleaned out my exhaust and when I checked it a few days later, it was black.
mike94fzr600
Level 4.5
Level 4.5
so than you know why your plugs are going bad. you are runnuin to rich
my rides
2000 chevy z71 4x4
1994 fzr 600
mike94fzr600
Level 4.5
Level 4.5
1 more thing how are your wires may be you have a bad set of plug wires
my rides
2000 chevy z71 4x4
1994 fzr 600
shredex
Post by shredex »
actually, my third wire was splt open from the fan blades but I used electrical tape on it and its do well.
shredex
Post by shredex »
my bike seems to have all its power at high rpm's....does this mean im to lean??
manveru
Level 3.5
Level 3.5
Post by manveru »
if your soaking your plugs and your exhaust is black, your not lean.
YAM93
Post by YAM93 »
there are "8" and "9" type plugs, i forget which one is "hotter". That can help or hurt with performance. Find out what you're using and try using the other type. (or check to be sure all 4 of yours are the same)
do a search or look it up, hopefully it's in the FAQ, Wiki, or, i'm quite sure it's in the Clymer or Haynes manual.
sorry i can't remember the specifics.
Post by sweekster »
Do you have a Clymer or Haynes Manual yet? Those help out a lot. Of course you should get that plug wire addressed. If it's just the rubber sheeting around the wires you should be able to cover that up with electrical tape and heat shrink. Well it should be replaced but in the mean time that will help. The NGK CR8E is the plug to use if you're running rich BUT you may want to go back into the carbs and adjust your needle settings and what not.
shredex
Post by shredex »
im using NGK CR9E spark plugs
FinaLd8ta
Post by FinaLd8ta »
i think ur running a colder plug swap out wit a cr8e witch is a hotter plug
also whats the spark gap for the plugs does any one kno ??
1989 FZR 600,
MODS: R6 master, clutch perch, and VR
93 FZR 4pot calipers (89 is 2 pot caliper)
and 4in X 18im rear rim (89 is 3.5in wide)
full muzzy exhaust, uni airfilter
BODY: choped tail, frame and rims black, Image
Vance/Hines engine covers
furture MODS
new plastics
R6 tail
race teck springs or r6 front susp
as of now she has no plastics on at all
