Yes ,I cut the tabs off one side of the mounts on either end of the brake arm and mounted the arm on one side of the swingarm tabs. Make sense?slayermd wrote:Hey, I have a Honda F3 rear wheel that is also a 160. The problem I have is the tire rubs against the brake arm. You have that problem at all?
Suzuki 17" Rim on stock FZR swingarm MOD (Testing Grounds)
- 100+ Posts
Re: Suzuki 17" Rim on stock FZR swingarm MOD (Testing Grounds)
- 100+ Posts
I would swap my swingarm too,but the rules in the vintage class I race would not allow it.95FZR600 wrote:So this has been accomplished? Looks really good with the 160. I will keep my 180 though!
- the_finch
- Level 8.5
What did you use for a rear rotor? I have a 97 bandit wheel (17x4.5 and same bolt pattern for the rotor). I bought a used GSXR 750 rear rotor with the proper bolt pattern, but it looks like the diameter is smaller than the stock FZR rotor. It also looks like the FZR600 rear rotor can't be made to fit.
Also, what gearing did you go with?
1997 FZR600RJ
- 100+ Posts
Depending on the year of GSXR they either used a 220mm rear disc or a 240mm rear disc. I used the 240mm. It is almost the same diameter as the fzr rear disc. The rear pads need to have some material removed as the GSXR 240mm rear disc is slightly smaller.
http://www.gixxer.com/forums/showthread.php?t=188067
- 100+ Posts
I just checked and I do have 1 of the 240mm rotors here if you need it Finch
- the_finch
- Level 8.5
PM'edCaptainCanuck wrote:I just checked and I do have 1 of the 240mm rotors here if you need it Finch
1997 FZR600RJ
- shredex
- 2000+ Posts
so can anyone tell me where I can get one of these suzuki rims???
- the_finch
- Level 8.5
I eBay'ed mine... from the looks of it a late 80's GSXR 750 or a 96-99 Bandit 600 both have 17x4.5 rear rim that match our bike pretty closely. I'm working with a 97 bandit 600 rim personally.
1997 FZR600RJ
- the_finch
- Level 8.5
I'm working on an information database concerning this swap for the Wiki. Stay tuned!
1997 FZR600RJ
- shredex
- 2000+ Posts
do you think this wheel will fit?
http://cgi.ebay.com/ebaymotors/1989-Kaw ... .m20.l1116
or this guy?
http://cgi.ebay.com/ebaymotors/89-97-Su ... .m20.l1116
or this one?
http://cgi.ebay.com/ebaymotors/89-Katan ... .m20.l1116
or this guy?
or this one?
shredex wrote:do you think this wheel will fit?
or this guy?
or this one?
The first one? No
The other 2? Probably so
- the_finch
- Level 8.5
First one- Definitely not. Nobody has managed to fit anything wider than a 160 into a stock swinger to my knowledge, and that looks like an "8" on the far left.sweekster wrote:shredex wrote:do you think this wheel will fit?
or this guy?
or this one?
The first one? No
2nd and 3rd - Probably so. I can tell you that (according to my research so far) the brake rotors, sprocket carriers, and sprockets will interchange between all years of the Katana 600 and 750, Bandit 600, 88 GSXR 1100, and 89 GSXR 750. They probably have the same rim width as well. I'll try to post the complete interchange list I have assembled so far tonight or tomorrow night.
1997 FZR600RJ
- shredex
- 2000+ Posts
better see some pics along with it!
- abs929cbrrr
- 1000+ Posts
just do a yzf600r entire rear swap...is so much simler and newer then a 20 year old rim.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
That would defeat the purpose of this Mod. Plus that makes the wheel base longer and the point of the mod is to keep as much of the original length and handling of the FZR intact along with opening the choices available for tires.abs600fzrr wrote:just do a yzf600r entire rear swap...is so much simler and newer then a 20 year old rim.
