On wednesday I met up with thatkid and we took a 2007 R6 passenger seat and threw it on the FZR frame for use with the airtech tail. That same day we also got heel guards put on, got an R6 brake master cylinder mounted and bled, changed the oil (in 2 bikes), swapped out my speedo drive, Mounted my undertail that was not mounting correctly, new clutch lever and perch mounted, passenger pegs mounted, modified exhaust bracket, relocated shock resevoir, relocated the yzf VR, stripped the paint off some fram plugs and bled the brakes on thatkids bike.
The first and scariest cut
Fiberglass protection. He got one and I didn't. What a friend
Early test fitting of the seat. God that day was full of test fitting
thatkid's amazing fabrication
Lots of welding
The supports well on their way.
Finished Supports (except we cut the middle ones off)
I gotta upload a few more pics of the finished product!
Oh, the VR got located between the undertail and the seat
