VR swap pics
fzrbrandon
Level 7.5
Level 7.5
VR swap pics
Post by fzrbrandon »
Hi everybody,
So I finally finished my VR swap and wanted to put up some pictures. I was thinking that these could supplement tommyj27's tutorial (which is the one I followed).
Brandon
P.S. I also replied to tommyj27's original thread. Sorry for the redundancy...
Image Image
http://www.fzrbrandon.com
tommyj27
Level 9.5
Level 9.5
Re: VR swap pics
Post by tommyj27 »
Thanks for the extra pics B. Everything working for you now?
fzrbrandon
Level 7.5
Level 7.5
Re: VR swap pics
tommyj27 wrote:Thanks for the extra pics B. Everything working for you now?
Seems like it. I started her up last night after finishing, kept it at 3k and was getting 14.26 to 14.29 across the battery. When I revved it up higher it only fluctuated by a couple hundredths of a volt. I even switched between hi / lo beam, hit the brake light, turn signals - she stayed right in the above mentioned range. That's good right? :-D Thanks for the great tutorial! :cheers:
So I'm now - RRBike Woo Hoo!
Brandon
P.S. How's the weather holding up? I'm from MN myself (Brooklyn Center HS - class of '89) :thumbsup:
Image Image
tommyj27
Level 9.5
Level 9.5
Re: VR swap pics
Post by tommyj27 »
Snowed here on Sunday. I was in Duluth for the weekend so I had a buddy grab my bike and ride it up to his place where I store it. 29 outside this morning, gonna get a little bit better into the weekend so I'm hoping to go riding a little more this weekend then winterize it. It will be a sad day, but I'll take my snowboard out to wax it and everything will be okay again.
95FZR600
Re: VR swap pics
Post by 95FZR600 »
I would put your grounds to the frame not on top of the aluminum.
Looks very clean though. Good job.
fzrbrandon
Level 7.5
Level 7.5
Re: VR swap pics
tommyj27 wrote:Snowed here on Sunday. I was in Duluth for the weekend so I had a buddy grab my bike and ride it up to his place where I store it. 29 outside this morning, gonna get a little bit better into the weekend so I'm hoping to go riding a little more this weekend then winterize it. It will be a sad day, but I'll take my snowboard out to wax it and everything will be okay again.
That's cool. Get the riding in while you can and have fun with the board! :headbang:
Brandon
Image Image
fzrbrandon
Level 7.5
Level 7.5
Re: VR swap pics
95FZR600 wrote:I would put your grounds to the frame not on top of the aluminum.
That's a good point. I'll try to do it the next time I'm able to sneak out to the garage for a few minutes. :whistle
Thanks!
Brandon
Image Image
shredex
Re: VR swap pics
Post by shredex »
i found this kit to let you make a plug for the VR
http://www.gdlcycles.com/asp1/modetails ... =FZR%20600
95FZR600
Re: VR swap pics
Post by 95FZR600 »
GDL is my favorite place to shop. I have also been down to their shop. Very good people.
tommyj27
Level 9.5
Level 9.5
Re: VR swap pics
Post by tommyj27 »
shredex wrote:i found this kit to let you make a plug for the VR
wow, i wish i would have had that when i did my VR! great find!
fzrbrandon
Level 7.5
Level 7.5
Re: VR swap pics
Hey, that IS pretty cool!
tommyj,
You should put this link in your tutorial. :thumbsup:
Brandon
Image Image
tommyj27
Level 9.5
Level 9.5
Re: VR swap pics
Post by tommyj27 »
done :D
shredex
Re: VR swap pics
Post by shredex »
tommyj27 wrote:done :D
still looking to see if I can find one at radioshack or something so I dont have to pay $20 for that harness.
one of the relay plugs on the FZR have the same plug, so if you have an old harness, then you can salvage the plug
tommyj27
Level 9.5
Level 9.5
Re: VR swap pics
Post by tommyj27 »
shredex wrote:one of the relay plugs on the FZR have the same plug, so if you have an old harness, then you can salvage the plug
also added :-D
shredex
Re: VR swap pics
Post by shredex »
ill take pictures of it tonight and see if it fits to conferm it. it looks the same though, so I imagin it will.
