Custom Ram Air Setup
FasterThanUr
100+ Posts
100+ Posts
Post by FasterThanUr »
I have finnished my ram air setup besides the body work.Haven tested it yet and wont beable to untill my new sprockets come in.The setup consists of the plastic top off a bondo can which fits perfectly over the air filter.Some PVC fittings and 1 1/2 inch PVC flex tube.Lots of super glue,gorilla glue and a good amount of fiberglass resin inside the lid thats at an angle to help the air flow downwards into the air filter.Also some smaller tubing for the float bowl pressure equalization.Heres a video and some pics of what i have going on.
http://www.youtube.com/watch?v=SDQy3BA2EHM
Equalization tube to the carbs
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I hooked my brake light switch to my throttle,so when I hit the gas everyone would slowdown and I would be gone :headbang:
R3TARD
Level 4.5
Level 4.5
Re: Custom Ram Air Setup
Post by R3TARD »
thats interesting looking. eager to see it installed with the body work
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
FasterThanUr
100+ Posts
100+ Posts
heres a couple more pics showing clearance.All the way to the left,the left controls touch but I never turn it that far anyway.Just a little bit more bondo and some sanding and it should be looking good :headbang:
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
jsph.mitch
100+ Posts
100+ Posts
Post by jsph.mitch »
I hope that works out.
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
Many more mods to come.....
FasterThanUr
100+ Posts
100+ Posts
jsph.mitch wrote:I hope that works out.
Im 99% sure it will.I might have to mess with the equalization tubes,but besides that there shouldent be any issues.I did a setup like this on my last bike,even tho it came from the factory with ram air all the components were gone when Igot the bike and I put it back together basically like I did with this.And it worked dead on the first try.
Heres some pics of the bondo sanded down.A little more prep tomorrow and I'll get it painted up...
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
95FZR600
Post by 95FZR600 »
:headscratch: interesting.
FasterThanUr
100+ Posts
100+ Posts
I got the body work and paint done.Got my new front sprocket and chain,but it's gonna be about two more weeks for my rear sprocket because Vortex has to have it custom made.So I just get to look at it for a couple more weeks and wont know if my work will pay off.
On a side note I also did my fork seals last night.One of the easiest and cheapest things I've done to the bike lol...
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
95FZR600
Post by 95FZR600 »
I need to do my fork seals to. Did you have to have any custom tools for the install? Something about a long rod to go through the tube?
PIMPMYFZR
Post by PIMPMYFZR »
FasterThanUr wrote:I got the body work and paint done.Got my new front sprocket and chain,but it's gonna be about two more weeks for my rear sprocket because Vortex has to have it custom made.So I just get to look at it for a couple more weeks and wont know if my work will pay off.
what is vortex doing so custom .. that hardening thing ..? i hope you ordered 2 :ermm:
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
YAM93
Post by YAM93 »
This is a pretty cool mod and the YouTube video sounds pretty good, and seems like it will work great.
Only thing I wonder is ... when you go to take the gas tank cover off... i guess the whole assembly will have to come off ?? The way you have it connected to the front fairing ... will that be an easy task ?
Nice job on the bondo / painting etc. also.
:thumbsup:
FasterThanUr
100+ Posts
100+ Posts
Why do you say that?But yes the hardening thing
YAM93 wrote: This is a pretty cool mod and the YouTube video sounds pretty good, and seems like it will work great.
It just kinda clips tightly to the front fairing and pulls right off with the cover.I just used fittings that were laying around besides the flex tube.I guess it would have been easier to spend a couple of bucks and got a 1 1/2 female to female 45 fitting so I could have just slid the hose's in and out,but this works fine :shocker
EDIT...
95FZR600 wrote:I need to do my fork seals to. Did you have to have any custom tools for the install? Something about a long rod to go through the tube?
I made a tool out of a small socket and welded some small pices of flat stock to it.Than I used two long and two short extentions with the ratchet.held the fork by the calliper mount in to the vice.held the ratchet in one hand and had the allen wrench with a breaker bar in the other end and it came right apart.
I was lucky enough to have a bunch of extra fork parts when I got the bike and there was some dampning tubes in there so it made it easy for me to make the tool :banana:
It's kinda a bad pic but heres the tool I made..
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
shredex
Post by shredex »
what are ya doing with the F4i? :whistle
FasterThanUr
100+ Posts
100+ Posts
shredex wrote:what are ya doing with the F4i? :whistle
thats the lady friends bike and she's quite fond of it and I dont see her getting rid of it untill her temptation to buy a harley overcomes her
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
shredex
Post by shredex »
the things covered in dust! tell her to get on that thing and take it for a ride! I hope theres not gas sitting in the carbs
FasterThanUr
100+ Posts
100+ Posts
shredex wrote:the things covered in dust! tell her to get on that thing and take it for a ride! I hope theres not gas sitting in the carbs
I hope theres not gas in the carbs being that it's fuel injected. :rofl:
All that dust is bondo dust from me doing body work.She dose need to take it out more,I'll start it up now and then to get it juices flowing :banana:
Tom Tom GPS
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
