Who has Pod's and Exhaust? What size main jet?
- Level 2.5
I just ordered K&N Pods and I had 118 mains in and went to 130 then 134...Its still lean...I may need 140's? Thats alot compaired to stock 107....But the Pod's dont create a vacuum(PULL) and you have to up the main to compensate. What size main is in yalls bike who has Pods and full flowing exhaust?....Thanks
2 wheels:
1994 Yamaha FZR 600,stage 3 dynojet,Supertrapp 16 disc exhaust,14-46 gear.
3 wheels:
1983 Honda Atc 200, superswampers, jetted,cobra exhaust..(IT REALLY FLOATS).
1984 Honda Atc 200E, Dead At the moment......
4 wheels:
1995 Chevy K-1500 Ext Cab (Blue) 2 layers of 5% tint...10in rims,33x12.59x16 mud terrian tires, dual exhaust..
Re: Who has Pod's and Exhaust? What size main jet?
Mine were done by a shop and I have not had to mess with them except for synching them last quarter at school. Wish I could be more help.
- Level 2.5
Man let me tell ya, I put the pods on and the 134 jets, and man does it pull before it runs lean....It has never pulled that hard... Cant wait til I get it tuned in good...Track time..I did run a 8.80@81mph stock...
2 wheels:
3 wheels:
4 wheels:
0-60? or to 100that cant be quarter mile .1BadFZR600 wrote:Man let me tell ya, I put the pods on and the 134 jets, and man does it pull before it runs lean....It has never pulled that hard... Cant wait til I get it tuned in good...Track time..I did run a 8.80@81mph stock...
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
- mike94fzr600
- Level 4.5
1\8 mile (360 ft) maybe
my rides
2000 chevy z71 4x4
1993 Suzuki Samurai my mud \ trail toy
1994 fzr 600
2000 chevy z71 4x4
1994 fzr 600
- Level 2.5
Yea 1/8 mile track........But now ive jetted, K&N, Valve job, new rings, 14-46 sprokets..I hope im 8.00 If feels alot better..What main jet are yall running?
2 wheels:
3 wheels:
4 wheels:
What jet kit are did you go with? I just put in FactoryPro stage 3 and started with the 117.5 with a full Yoshi system. I think Nate is running 128's but that's the biggest I've ever seen before.
- Level 2.5
Dynojet......Yea Ive got in 134 and its too lean at WOT!!!
2 wheels:
3 wheels:
4 wheels:
the mains don't do anything at WOT. That's where the needles play the roll. You need adjustable needles. I'm running a full 4-2-1 exhaust, twin pods, flo-commander, ford coil pack with .040(I think) plug gap, and dyno jet kit without the slides drilled. I've got 128's I think and my needle position is wrong. I haven't bothered to get in there yet cause it runs well around town and that's most of what I'm doing these days. My top end bogs but since I don't ever really flog the bike I hardly notice it. 135 is WAY too big. You need to work on the needles. They kick in around 7.5k
Do YOU Scopper?
Mains do most of the fuel metering at full throttle above 7.5k, have a read of CV carb tuning on the factorypro website. They do also effect the fuel metering at other parts of the rev range to a lesser extent at WOT. Think of the needles as valves as to how far open the main jets are, when the needle is all the way up its getting close to full flow, when the slides and needle are only part way up at say 6.k its getting partial flow.
- Level 2.5
Ive got Dynojet, needles on the 3rd slot...ordered bigger mains...Be here in a day or two.....
2 wheels:
3 wheels:
4 wheels:
maybe this graphic will help some, but yes the mains are all WOT
As far as rich and lean, there is such a thing as a rich stumble with too big a main..lean should feel reluctant to take throttle, or more throttle, but a huge main will also cause a stumble, like a false rev limit...id see about a dyno tune
1987 FZR1000 piped, jetted, pods, painted blue just your average 20 year old bike, runnin strong
- Level 2.5
My pilot jets are also stock, and they are too lean at cruisin 60 mph, Ive got the next size pilots ordered too...be here thur...im going with 140 main and 35 pilot and see what happens...
2 wheels:
3 wheels:
4 wheels:
