sweet, this is exactly what i needed to know. thanks man.PIMPMYFZR wrote:tampaFZR600 wrote:
heres the sku # for the bearings ...BEARING,CYL.#20
360538-001
YZF SWINGARM SWAP..... DONE!
- tampaFZR600
- Level 4.0
Re: Another YZF swingarm?! UGH, enough already!
- tampaFZR600
- Level 4.0
OK! I got the gold 520 chain from bmiller for 50 bucks and a rear 47t 520 JT sprocket at motorcyclesuperstore for 34 bucks. SAAAWWEEEET. THanks fellas!
....still need the bearings.....expensive bitches....
Going to go do my swingarm now woot!
tampaFZR600 wrote:OK! I got the gold 520 chain from bmiller for 50 bucks and a rear 47t 520 JT sprocket at motorcyclesuperstore for 34 bucks. SAAAWWEEEET. THanks fellas!
Cool. meausre twice cut once. I cut .375 off of each end. Make sure you use a machinist ruler in the 100th scale to accurantely make tyour marks.
- tampaFZR600
- Level 4.0
Well, i went to etch the lines today, and the clamps worked perfect...here are some pictures of the clamps and then the lines without the clamps, look pretty strait! I measured with a micrometer to .375 or 3/8" on each side. From line to line, 8.5"----MONEY! Then i thought...well, i can get out the cutting wheel and cut around this circle....... OR i can go back to my old shop and have a buddy (that is very good on the band saw) buzz these ends off in .2 seconds. So i called him up and he said the boss is out tomorrow so he can do it at lunch AND he's gonna sandblast it for me! YEEEYAAA!
- tampaFZR600
- Level 4.0
Thanks again man!BMiller wrote:Good to see the progress! I'm shipping you that chain first thing in the AM.
I'm doing the same conversion and I'm just wondering;
Are the rear sprockets of all YZF 600 94-02 the same?
Wich year 636 front sprocket fits?
And where to buy cheapest?
- tampaFZR600
- Level 4.0
EVERYTHING you need to know is in these three links, I read and re-read each of them MANY times, and feel like i'm a pro now.fzraudun wrote:I'm doing the same conversion and I'm just wondering;
viewtopic.php?f=30&t=2851
viewtopic.php?f=30&t=563
viewtopic.php?f=30&t=178
to more directly answer your question, i believe the years are 95-07 for the yzf swing.
03-06 zx6r 636 front sprocket, http://www.denniskirk.com cheapest
also, you need to get a 520 chain and change the YZF stock 530 sprocket to a 520 sprocket
have fun!
1. Yes......You can use a FZR 520 sprocket if your currently have one but just open up the bolt holes a bit.
2. JT1307 is the one you want. ( 14 or 15 tooth your preference )
3. Ebay has them for about 22 shipped. Years and models are in the pics below. 1st link below is for the 14 tooth ( one I got ) the second is for the 15 tooth. I beleive they have a 13 tooth also.
http://cgi.ebay.com/ebaymotors/JT-Front ... ccessories
3. Ebay has them for about 22-23 shipped. Dennis Kirk has them for about 28-29 shipped. Ebay makes more sense. Years and models are in the pics below. 1st link below is for the 14 tooth ( one I got ) the second is for the 15 tooth. I beleive they have a 13 tooth also.
- tampaFZR600
- Level 4.0
I stand corrected. I paid 26 on dennis kirk. that one on ebay is cheaper
going to go pick up a 05 swinger for 40 bucks, no hardware....worth it?
- tampaFZR600
- Level 4.0
YZF600 or R6?....i guess it doesn't really matter, either would be an ok deal i think.war2008 wrote:going to go pick up a 05 swinger for 40 bucks, no hardware....worth it?
on ebay you can get a R6 or Y600 for $50-$100 shipped, some with extra parts, so i would check that out.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem=
This auction is for an OEM rear wheel swingarm for the 2003 - 2005 Yamaha YZF600R6. This is the OEM unit and it should fit the R6 of any year,
- tampaFZR600
- Level 4.0
OOO yea, so i got my ignition and key set from thatkid yesterday, and also got my swingarm CUT and blasted
My friend said its 1/32 OVER, so thats PERFECT,I have a tiny bit to work with...
