R6/R1 gauges and Yzf blue dot calipers
How easy/hard is it to put the blue dot's on the fzr. And whats easier to swap, the r1 gauges or r6 gauges. Or is there an easier digital gauge setup thats easier to install. Thanks for the help/info guys.
...ROGO...
1993 Yamaha Fzr 600-RIP
Stock
1990 Yamaha Fzr 600-Current
Mods
Updated R6 Voltage Regulator/Rectifier
Flush mount Front Signals
R6 Headers Modded By That-Kid
Leo Vince R6 Highmount Exhaust
520 Chain and Sprocket Conversion
YZF600R Front End Swap
Front and Rear YZF600R Brake Swap
YZF600R Swingarm Swap
92 Fzr Single Upper
8000k HID Headlight Kit
95 YZF600R Gauge Cluster
02 R6 Tail, Fender Eliminator and Intergrated Tailight
YZF600R Gas Tank
Rear Tire Hugger
http://www.myspace.com/rogo420
facebook---Andrew Rogo Rogowski
Fzr Forum===WnyRogo93Fzr
Stock
Mods
92 Fzr Single Upper
YZF600R Gas Tank
Rear Tire Hugger
Re: R6/R1 gauges and Yzf blue dot calipers
WNY ROGO wrote:How easy/hard is it to put the blue dot's on the fzr. And whats easier to swap, the r1 gauges or r6 gauges. Or is there an easier digital gauge setup thats easier to install. Thanks for the help/info guys.
The calipers are a bolt on swap. Hardest part is bleeding them after you put them on. As far as the gauge swap is concerned...click here
Hmmm dosent seem too tough, just costly.......
...ROGO...
Stock
Mods
92 Fzr Single Upper
YZF600R Gas Tank
Rear Tire Hugger
Stock
Mods
92 Fzr Single Upper
YZF600R Gas Tank
Rear Tire Hugger
read the write up on the gauges as it involves drilling into your transmission case for a speed sensor
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
Full Brake write up:-WNY ROGO wrote:Hmmm dosent seem too tough, just costly.......
http://www.saltmine.org.uk/fzr/frontbrakes.html
as to digital tach stuff there appears to be some still unfinished business with the R1 set up as far as the tacho is concerned if memory serves
The required electronics Circuit is shown on :-
http://www.saltmine.org.uk/fzr/digitalclocks.html
R1 gauges would be the easiest if you can get the tach converter for it.
