tires
Tyres
- Tire Pressure (33 psi front, 36 psi rear)
- Rear tyres:-
- Bridgestone 18“ diam BT-014 (18” * 140)
- Avon 18“ diam AV56 ( 18” * 150 )
- Pirelli Dragon 18“ ( 150/60-ZR18)
- Pirelli Diablo Strada successful fitting on a 93 FZR stock swing 160/60/18
- If you have a '91+ FZR600 with stock swing arm 150 tyre is the biggest that will fit !!!
- No you don't rotate motorcycle tires
tires.1236360207.txt.gz · Last modified: 2020/10/19 11:47 (external edit) · Currently locked by: 216.73.217.74,10.8.105.140
