synch_tool
Home made 2 Bottle type carb sync tool
Postby Shredex »
Sat Feb 28, 2009
If you are thinking about building a carb sync tool, then I would recommend using the 2-bottle method. I just used it and it works wonders! SUPER fine tuning…My bike revs so smooth now. it sounds so beautiful.Iv tried the stick and tubing method, all telecharger poker I can say is, it sucks and you can risk sucking liquid into your motor.
Material List
2 off GLASS bottles (I used two 9.5oz Starbucks Frappuccino bottles) NOT plastic bottles
12Ft of 3/8“-1/4” clear pvc tubing (the outside is 3/8“, and the inside is 1/4”)
1 off 3/8“ sharp metal drill bit
2 off rubber stoppers OR rubber chair leg plugs/bumpers (I used 1.5” chair leg plugs)
4 off 6mm mig welder tips (there is ten in a pack)
optional
2 off “Y” connectors that fit the 1/4“ tubing.
2 off 1/4” rubber caps
# Zip-ties as required
Pictures
Thanks to CAD600 for his photo's of how he did it
This one below is Sweekster finish tool
Thanks to both Sweekster for his Photo & write up & CAD600 for his detailed photo set Edited by Y_G
synch_tool.txt · Last modified: 2020/10/19 11:50 by 127.0.0.1
