tci-repair
**A basic TCI repair**
Best of Luck TrifGeorge
Well some additional information has come to hand:-
Top to bottom: Br B R Gd = 1k, 5% Zener, unknown, band left in your pic. “A2” marking on the side; no idea what the rating is. Logic suggests it's either 5v or 12v; try 5v first so you don't burn anything that doesn't like 12v! Bl R Br Gd = 620, 5% R R R Gd = 2.2k, 5% Bl R Br Gd = 620, 5%
The tach signal is tied into the 2-3 spark signal. The earlier model tachs simply picked up the fly-back pulse from the coil, while the newer tachs want a 12v or 5v signal from the TCI (not sure which voltage; this will very likely be tied into the Zener diode rating).
The tach may come back to life once you replace the TO-220 ignition transistor.
tci-repair.1308321487.txt.gz · Last modified: 2020/10/19 11:49 (external edit) · Currently locked by: 216.73.216.42,10.1.138.54
