synch_tool
  • Edit post
  • Delete post
  • Report this post
  • Warn user
  • Information
  • Reply with quote
Home made carb sync tool
Postby shredex » Sat Feb 28, 2009 5:13 am If you are thinking about building a carb sync tool, then I would recommend using the 2-bottle method. I just used it and it works wonders! SUPER fine tuning… My bike revs so smooth now. it sounds so beautiful. Iv tried the stick and tubing method, all I can say is, it sucks and you can risk sucking liquid into your motor.
Things you will need: 2 GLASS bottles (I used two 9.5oz Starbucks Frappuccino bottles) 12' of 3/8“-1/4” clear pvc tubing (the outside is 3/8“, and the inside is 1/4”) 1 3/8“ drill bit 2 rubber stoppers OR rubber chair leg plugs/bumpers (I used 1.5” chair leg plugs) 4 6mm mig welder tips (there is ten in a pack) optional 2 “Y” connectors that fit the 1/4“ tubing. 2 1/4” rubber caps # Zip-ties
synch_tool.1289909945.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
