remove_the_flywheel
How to Remove the Flywheel
  • Time: 30 minutues
  • Required Tools: 5mm allen, flywheel puller, hammer, socket wrench
Directions
  6. After removing the flywheel there should be a flywheel tab that holds it in place, don't loose this.
remove_the_flywheel.1212471000.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
