r6_99-02_r6_swingarm_swap
99-02 R6 SWING ARM SWAP
Materials List
- R6 Swing Arm
- Rear caliper
- Master Cylinder
- Rotor
- Hub w/bolts
- Axle w/spacers
- Rim and tire 180/55/17
- Shock w/fab mount
- 520 Rear Sprocket
- 520 Zx6r Front Sprocket I went 14 front 47 rear
- 520 Chain w/120 link
- Chain Adjusters
- Swingarm w/shock
- Entire Assembly
- Old Assembly
- FZR Swinger Removal
- FZR Front Sprocket
- Old vs. New Front Sprocket (zx6r front)
- Me grinding away
- Cut off heal guard bracket
- Zx6r Front Sprocket Installed
- Pivot bolt hole
- Frame bushings right side (hardened steel)
- Frame bushings left side(hardened steel)
- Rear view
- Pivot bolt bushing
- Difference I had to cut
- Checking for clearance
- YAY it fits
- Closer view
- Want to thank my best friend Derek for bringing the bottle of Morgan
- And helping with the build!!
- Spaced out the master cylinder and brake switch to align with bracket
- Fabbed up upper shock mount
r6_99-02_r6_swingarm_swap.1233447088.txt.gz · Last modified: 2020/10/19 11:49 (external edit) · Currently locked by: 216.73.217.74,10.8.105.140
