r6_99-02_r6_fork_swap
Materials List:
  • 99-02 R6 Triples or any other YEARS will work
  • Fork Tubes
  • Clipons from same year you choose
  • Use your existing bearings,spacers and dust caps
  • In the future we will be using a double ended bushing for top and bottom.
r6_99-02_r6_fork_swap.1233441832.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
