The components
Does that all make sense? :)
Ok i done the mod Yesterday
Turn/Blinker, dark/Green Positive, dark/Brown Positive (light/Green some US models)
Neutral Brown Positive, light/Blue Negative
We need to cut these wires
The holder cut off, i left around 1 inch of wire on the holder, the small piece of wire top right i cut that amount from both wires loom/harness side, so the wires tuck back in tidily don't want them to long
The diodes soldered and heat shrinked to the lamp holder, i chose the dark/Green wire but its unimportant
The wider heat shrink in place, a nice weather proof seal
Now we need a ground/earth, the high beam is sat next door we know Yellow is Positive, so the Black is an ideal ground/earth to splice into, i bared the insulation back with a utility knife, then soldered the 2 wires, and insulated with self-amalgamating tape again a nice weather proof seal
Taped up and finished (sorry for the blurry photo), just need to fit the other 3 led's make sure the anode (Positive) goes to the corresponding lamp positive
The led's working
Inside the speedo lamp covers removed, you may need to do this depending on how bright your led's are (i had to) 10mm led top, 5 mm led bottom, the extra 10m led i added side
Close up of the extra led, i soldered it to the top led legs, fixed it to the speedo body with double sided foam sticky tape
led_instrument_warning_lamp_conversion.1273835667.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
