The components
Does that all make sense? :)
Ok i done the mod Yesterday
Turn/Blinker dark/Green Positive, dark/Brown Positive (light/Green some US models)
We need to cut these wires
The holder cut off, i left around 1 inch of wire on the holder, the small piece of wire top left i cut that amount from both wires loom/harness side, so the wires tuck back in tidily don't want them to long
The diodes soldered and heat shrinked to the lamp holder, i chose the dark/Green wire but its unimportant
The wider heat shrink in place, a nice weather proof seal
Now we need a ground/earth, the high beam is sat next door we know Yellow is Positive, so the Black is an ideal ground/earth to splice into, i bared the insulation back with a utility knife, then soldered the 2 wires, and insulated with self-amalgamating tape again a nice weather proof seal
Taped up and finished (sorry for the blurry photo), just need to fit the other 3 led's make sure the anode (Positive) goes to the corresponding lamp positive
led_instrument_warning_lamp_conversion.1273833851.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
