The components
Does that all make sense? :)
Ok i done the mod Yesterday
Turn/Blinker dark/Green Positive, dark/Brown Positive (light/Green some US models)
We need to cut these wires
The holder cut off, i left around 1 inch of wire on the holder, the small piece of wire top left i cut that amount from both wires loom/harness side, so the wires tuck back in tidily don't want them to long
led_instrument_warning_lamp_conversion.1273832692.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
