The components
The diodes soldered to some makeshift wires, imagine they are the blinker wires from the harness/loom side (light/Green dark/Green some US models, dark/Green Brown other models)
Does that all make sense? :)
led_instrument_warning_lamp_conversion.1273640570.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
