The components
Left 1 x 430 ohm resistor Right 2 x 1N914 100v 75mA Signal Diode Bottom Left 1 X 10mm white led Bottom right 1 x 10mm capless led holder
The diodes soldered to some makeshift wires, imagine they are the blinker wires from the loom side (light/Green dark/Green some US models, dark/Green Brown other models)
Does that all make sense? :)
led_instrument_warning_lamp_conversion.1273640324.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
