The components
Left 1 x 430 ohm resistors Right 2 x 1N914 100v 75mA Signal Diode Bottom Left 1 X 10mm white led Bottom right 1 x 10mm capless led holder
http://mawler.org/bike/Led/components.jpg
http://mawler.org/bike/Led/longleg.jpg
http://mawler.org/bike/Led/ledres.jpg
http://mawler.org/bike/Led/anodeleg.jpg
The diodes soldered to some makeshift wires, imagine they are the blinker wires from the loom side (light/Green dark/Green some US models, dark/Green Brown other models)
http://mawler.org/bike/Led/diodessolder.jpg
http://mawler.org/bike/Led/wired.jpg
http://mawler.org/bike/Led/whiteblue.jpg
http://mawler.org/bike/Led/bluewhite.jpg
After pi**ing around putting the led together, i remembered i had 4 pre-made ones :duh: got them of eBay for around £2, was going to use them for my dash lights, but opted for Red led's (bikes Red)
http://mawler.org/bike/Led/premade.jpg
pulled 1 open to identify the anode, the resistor (left leg) is the anode, diode (right leg)is the cathode, diodes there to protect against reverse polarity (led could blow)
http://mawler.org/bike/Led/resdiode.jpg
LED's don't get hot use less power, and have a long life span,& do not break filaments when hot and suffer from vibration stress ) coloured ones look pretty in the dash :) But stick to white for the warning lamps.
Does that all make sense? :)
led_instrument_warning_lamp_conversion.1273600275.txt.gz · Last modified: 2020/10/19 11:48 (external edit) · Currently locked by: 216.73.217.74,10.8.105.140
