how_to_adjust_your_valve_clearances
FIXME
  • Difficulity: medium
  • Attention to detail: medium
  • Remove valve cover (8mm)
  • Remove chain guard
how_to_adjust_your_valve_clearances.1223869447.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
