* FZR 600 {3HE} front rotors = 7.26 lbs
- FZR 600 rear wheel (18 x 4.0)(with cush drive, sprocket carrier (no sprocket) and brake disk) = 22.35 lbs
- FZR 400 Front (17 x 3.0) = 10.5 lbs (wheel) + 6.44 lbs (Rotors)
- FZR 400 {1WG} rear wheel (18 x 4.0) (with cush drive, sprocket carrier (no sprocket) and brake disk) = 19.32 lbs
- FZR 400 {3tj} rear wheel (17 * 4.5“) with cush drive , sprocket carrier and disc only) 8.38Kg = 18.474 lbs
- TZR 250 rear wheel (17 x 4.5) (with cush drive, sprocket carrier (no sprocket) and brake disk) = 14.65 lbs
- TZR 250 rear wheel with cush tire and sprocket is 31.24lbs
- FZR 400 {1WG} swing arm with rear axle 3.1KG = 6.834 lbs
- FZR 400 {3EN} reinforced as stock with axle 7.4 Kg = 16.314 lbs
- 96-99 SRAD S/arm with shock linkage,axle,pivot bolt,brake caliper,caliper arm weighs exactly 10kg or 22lbs
- '03 GSXR 600 rear wheel 5.5”X17 with a dunlop tire,cush,sprocket & rotor wieghs 14.8kg or 32.5lbs
- '05 GSXR 600 front end with calipers, damper, controls, Everything on except wheel is 15.6kg or 34.3lbs
- 06 GSXR 1000 front wheel with bridgestone slick and stock rotors on there is 11.2kg or 24.6lbs
- 06 R6 subframe 1.8kg or 3.97 lbs
- 08 R6 subframe 1.350Kg or 2.97 lbs { ie 450g lighter or roughly 1 lb}
- FZR400 IWG Stock subframe with undertray, tail light, no battery box, and foot pegs is 8.4kg or 18.5lbs
- Fox Twin Clicker Rear shock 3.6kg or 7.92 lbs
- FZR 600 stock Rear shock 2.52 kg or 5.54 lbs
- FZR 400 huge battery weighs 4.4kg or 9.7lbs
fzr_other_models_parts_weights.1273143300.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
