  • FZR 600 {3HE} front rotors = 7.26 lbs
  • FZR 400 {3tj} rear wheel (17 * 4.5“) with cush drive , sprocket carrier and disc only) 8.38Kg = 18.474 lbs
  • FZR 400 {1WG} swing arm with rear axle 3.1KG = 6.834 lbs
  • FZR 400 {3EN} reinforced as stock with axle 7.4 Kg = 16.314 lbs
  • '03 GSXR 600 rear wheel 5.5”X17 with a dunlop tire,cush,sprocket & rotor wieghs 14.8kg or 32.5lbs
  • Fox shock 3.6kg or 7.92 lbs
fzr_other_models_parts_weights.1272754619.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
