  • FZR 600 {3HE} front rotors = 7.26 lbs
  • FZR 400 £tj rear wheel (17 * 4.5“) with cush drive , sprocket carrier and disc only) 8.38Kg = 18.474 lbs
  • '03 GSXR 600 rear wheel 5.5”X17 with a dunlop tire,cush,sprocket & rotor wieghs 14.8kg or 32.5lbs
  • Fox shock 3.6kg or 7.92 lbs
fzr_other_models_parts_weights.1272754037.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
