The DATA here was originally started by Palfrey & FreeStyle
  • FZR 600 front rotors = 7.26 lbs
  • FZR 400 rear wheel (18 x 4.0) (with cush drive, sprocket carrier (no sprocket) and brake disk) = 19.32 lbs
  • TZ 250 rear wheel with cush tire and sprocket is 31.24lbs
  • '03 GSXR 600 rear wheel 5.5“X17 with a dunlop tire,cush,sprocket & rotor wieghs 14.8kg or 32.5lbs
fzr_other_models_parts_weights.1272720636.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
