The DATA here was originally started by Palfrey & FreeStyle
  • FZR400 Front (17 x 3.0) = 10.5 lbs (wheel) + 6.44 lbs (Rotors)
  • FZR600 front rotors = 7.26 lbs
  • FZR600 rear wheel (18 x 4.0)(with cush drive, sprocket carrier (no sprocket) and brake disk) = 22.35 lbs
  • FZR400 rear wheel (18 x 4.0) (with cush drive, sprocket carrier (no sprocket) and brake disk) = 19.32 lbs
  • TZR250 rear wheel (17 x 4.5) (with cush drive, sprocket carrier (no sprocket) and brake disk) = 14.65 lbs
  • TZ250 rear wheel with cush tire and sprocket is 31.24lbs
  • '03 GSXR600 rear wheel 5.5“X17 with a dunlop tire,cush,sprocket & rotor wieghs 14.8kg or 32.5lbs
  • '05 GSXR600 front end with calipers, damper, controls, Everything on except wheel is 15.6kg or 34.3lbs
I don't have the front wheel yet but will post when I do.
fzr_other_models_parts_weights.1272641356.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
