Parts List
  • Electrosport Speedsensor S4
  • Electrosport Wiring Kit
Wiring to the Stock Harness
Nine Pin Connector Layout
[Top Notch]
Six Pin Connector Layout
[Top Notch ]
Blank Blank Blank
Red(2X) : A&B Connector Power Black(2x) Yellow : Tachometer
The tachometer wire that Acewell/Electrosport supplies with the kit is extremely long for those that wish coil it around an ignition coil. Since I intended to tap the wire into the stock harness I snipped the excess, and using a male female spade connector; I used the excess wire to run the Brown Clock Power Wire through the frame to the positive terminal on the battery (1/4 inch 22 gauge spade at the terminal). In the picture above you will see the brown wire joined to a yellow wire by way of a red spade connection.
-ShogunTX (Original concept by MsHap visit her site Jello's Homepage)
electrosport_gauges_digital_upgrade.1222042514.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
