SWING ARM DIMENSIONS
THE ABOVE WAS SUPPLIED BY :- TRIFGEORGE and added by Y-G 2010-12-27
Oil Cooler Swap
Oil Cooler off FZ600, FJ600, XJ650 is a bolt-on mod for 'cartridge' (internal) oil filter FZR600 & FZR400. The same parts numbers were used on all 3 models.
Later FZR600 with spin-on filter ('91+) must trim ~3mm from the central union bolt on the cooler, to allow the spin-on adaptor plate to seat. http://fzronline.com/forum/viewtopic.php?f=7&t=610&p=4708#p4708 Info stolen from dru86
Supplied By DonTZ125 & edited by Y-Geo 2011/04/06
Cam swapping
Yes the fzr600 cams have about 1mm more lift and is common to put in a 1wg fzr400, when the 2tk come out they increased the lift to the same as the fzr600. All later fzr400s also had this increased lift( i measured both the 2tk cams and the 3en1 cams), not sure about the profiles though but I'd say they were the same.
The yzf600 is also exactly the same as the fzr600. I measure the lift and I sent one of each intake off to the cam grinder for checking. They said they were the same profile.
Supplied by Drue86 & Edited by Y-Geo.
database_of_yamaha_parts_you_can_use_for_swapping.1305994566.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
