SWING ARM DIMENSIONS
THE ABOVE WAS SUPPLIED BY :- TRIFGEORGE and added by Y-G 2010-12-27
Oil Cooler Swap
Oil Cooler off FZ600, FJ600, XJ650 is a bolt-on mod for 'cartridge' (internal) oil filter FZR600 & FZR400. The same parts numbers were used on all 3 models.
Later FZR600 with spin-on filter ('91+) must trim ~3mm from the central union bolt on the cooler, to allow the spin-on adaptor plate to seat. http://fzronline.com/forum/viewtopic.php?f=7&t=610&p=4708#p4708 Info stolen from dru86
Supplied By DonTZ125 & edited by Y-Geo 2011/04/06
database_of_yamaha_parts_you_can_use_for_swapping.1302118849.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
