SWING ARM DIMENSIONS
THE ABOVE WAS SUPPLIED BY :- TRIFGEORGE and added by Y-G 2010-12-27
OIL Pan Swap
Oil Coolers off (unless the UK '90 FZR600 was substantially different from the US model) is a bolt-on mod from any of the following bikes an FZ600, FJ600 and the XJ650. The same parts numbers were used on all 3 models.
Supplied By DonTZ125 & edited by Y-Geo 2011/04/06
database_of_yamaha_parts_you_can_use_for_swapping.1302101032.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
