SWING ARM DIMENSIONS
THE ABOVE WAS SUPPLIED BY :-
         TRIFGEORGE and added by Y-G 2010-12-27
OIL Pan Swap
unless the UK '90 FZR600 was substantially different from the US model, cooler is off an FZ600, but it's a bolt-on mod. The same parts were also used on the FJ600 and the XJ650.
Supplied By DonTZ125 & edited by Y-Geo
database_of_yamaha_parts_you_can_use_for_swapping.1302100665.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
