carburetor_page
Carburetors
How it works
FIXME
Removing
Instructions:
  1. Remove Seats
  2. Remove tank cover
  3. Remove airbox
  4. Remove gas tank
Throttle cables
FIXME
Jetting
FIXME
Syncing
FIXME
http://fzronline.com/forum/viewtopic.php?f=21&t=6089 A picture is worth 1000 words.(Carb Sync Tool)(Feel free to edit or use pictures)
http://www.allthingsmoto.com/forums/f-15/how-set-your-motorcycle-carburetor-float-level-more-commentary-13608/ An explanation of float height setting with tech terms explained
Idle Adjustment
VIDEOS
FZR600 carburetor cleaning (by match417)
small:k5R5XBI-I9U
Drilling out EPA caps (by match417)
small:qu3-3-RqDy4
Bench sync FZR600 carbs (by match417)
small:rUJUNG7sMfI
carburetor_page.1349963057.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
