carb_synch_tool
   ==== Synch Tool Design ====
Sent: Sat Nov 13, 2010 -
I built this:-
http://fzronline.com/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=20862&width=113&height=150
and here are the details:
Material: 7 ft per cylinder total (28 ft) 5/16 in OD 3/16 in ID vinyl tube
4 off 6mm brass welding tips Wood molding with 4 channels to lay the tube in (found at Lowes)
Recommended marvel Mystery oil or some other high viscus oil 3 oz?
2 off “T” 5/16 in couplers (I used 1/4 in and that worked fine)
2off inch length of 3/16 hose to connect the remaining unions together
Instructions:
Cut EQUAL lengths of tube 6 or 7ft (either will be just fine)
Drill 4 hole in the top and 4 holes in the bottom of the wood molding
Paint wood white LET IT DRY THOROUGHLY
Mark lines with a T-Square as desired for reference
Pull PLASTIC lines through holes
Connect all lines at bottom of the tool ( properly called a Manometer) with T's and extra 2 inch tube
Super glue the lines to the wood (make sure paint is dry)
Add oil at the bottom end using a plews type liquid pump if you have one, otherwise gravity feed
have fun with your new tool Fizzer6Hundred
carb_synch_tool.1289652603.txt.gz · Last modified: 2020/10/19 11:48 (external edit) · Currently locked by: 216.73.216.42,10.1.138.54
